ATL 5G R16 (RG520F-EU) — No traffic on LTE after 5G→LTE handover with Wind/3 Italy
Hello everyone,
I am experiencing a persistent issue with my MikroTik ATL 5G R16 and Wind/3 Italy operator. I have tested multiple RouterOS versions (7.19.6, 7.20.7, 7.20.8, 7.22.1) and the problem is present in all of them.
--- HARDWARE ---
Device: MikroTik ATL 5G R16 (model: ATLGM)
Modem: RG520F-EU (revision: RG520FEUEAR03A04M4GX)
--- OPERATOR ---
Operator: Wind/3 Italy (WINDTRE)
APN: myinternet.wind
Authentication: none
IP-type: auto
Perhaps make a supout.rif file when/after the issue occurs and submit a support request to mikrotik.
(Is there an update to the ATL's firmware available?)
Hi Tony, have you solved the problem? Because I'm facing the same issue. Thanks Bruno
Hi Bruno,
unfortunately MikroTik never released a fix as far as I know (still seen on 7.19.6 → 7.22.1). What I ended up doing is a workaround: I disabled 5G entirely and locked the modem to LTE bands only, so the 5G→LTE handover never happens:
/interface lte set lte1 band=3,20,28 nr-band=""
(3/20/28 are the Wind/3 LTE bands in my area, adjust to yours). I also moved the ATL outdoors (RSRP improved by ~23 dB, now around -78 dBm) and added a TCP MSS clamp on lte1. Since then it has been stable as a backup WAN. You lose 5G speed (in my tests ~113/26 Mbps on LTE vs ~173/61 on 5G NSA), but the connection doesn't freeze anymore.
If you want to keep 5G, the other option is a netwatch script that resets the modem when traffic stops, but I didn't go that way.
Good luck!
Hi Tony,
I asked support to ChatGPT. The AI suggested me this change
  • Restricted lte-bands to B1, B3, B7 only (excluding the congested B20 band so B3@20MHz acts as a stable primary anchor band).
  • Restricted nr-bands to n78 only (excluding n38 to prevent the Quectel RG520F-EU modem from stalling when aggregating dual TDD carriers n78 + n38 on a weak NR signal).
Now let's see if it works.
Regards Bruno
