ATL LTE18 kit - IPSec offload
Hello
anyone knows the exact specifications about the IPSEC hw offload?
I have tried 128/256 AES-CBC CTR and GCM, SHA1/256 and always appears AEAD offload enabled.
To be sure I have enabled 256/CTR and SHA256, it seems working fine with low cpu.
anyone has more precise informations?
are you sure that ATL supports IPSec HW offload? There is no separate results there: https://mikrotik.com/product/atl18#fndtn-testresults
These devices that support offload have special IPSec section listed.
Well, I dont know if they support IPSEC HW offload or not, this is the reason I asked on the forum. Maybe the ARM cpu already has some instruction onboard.
In the IPSEC section, I see the H for HARDWARE AEAD enabled…
The cpu is quite low if I try to pass some encrypted traffic.
If we search on the docs:
88F3720 that is the CPU of the ATL…
https://www.marvell.com/content/dam/marvell/en/public-collateral/embedded-processors/marvell-embedded-processors-armada-37xx-hardware-specifications.pdf
 IPsec • IPsec ESP and AH Packet Transform • Support for latest Ipsec RFCs (3566, 430x, 4434, 4543, 4868) • Extended Sequence Number Support • Replay protection • Full header and trailer processing • IPv4/IPv6 support (RFC-4301) and header updates
here:
https://gzhls.at/blob/ldb/2/7/4/2/6eacf9661c5a2d20c4d7cd3328ffba47bfd6.pdf
Security • High-performance security offload engine including IPSec, SSL, DTLS, and IKE
