Attack by SSH ..
this is an example for what i see every day in my router os log :
sep/10 23:32:20 system,error,critical login failure for user save from 218.189.137.70 via ssh
sep/10 23:32:29 system,error,critical login failure for user styx from 218.189.137.70 via ssh
sep/10 23:32:39 system,error,critical login failure for user toto from 218.189.137.70 via ssh
sep/10 23:32:48 system,error,critical login failure for user tuningar from 218.189.137.70 via ssh
its just an example , pages of this every day !!
how i can stop this attack please ??
/ ip firewall filter
add chain=input protocol=tcp dst-port=21-22
src-address-list=!secure-addresses action=drop comment=“Only allow FTP
and SSH from our network” disabled=no
Define a list called “secure-addresses” and put all your allowable subnets. This will shutdown those brute force attacks.
Eric
You can also Disable Option from
/ip service disable=ssh
Or change default ssh port to something else like 222.
Use the following, it will give them 3 login attempts then adds them to a blacklist for 7 days
add chain=input protocol=tcp dst-port=22 src-address-list=black_list action=drop \
    comment="drop ssh brute forcers" disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new \
    src-address-list=ssh_stage3 action=add-src-to-address-list address-list=black_list address-list-timeout=7d \
    comment="" disabled=no
    src-address-list=ssh_stage2 action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m \
    src-address-list=ssh_stage1 action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m \
    action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m comment="" \
    disabled=no
Which means you can still use ssh if you need to.
