I haven’t used an Audience hardware - can is be configed with Winbox? and if so, could someone share its default config? I would like to maybe build something like that with other outdoor hardware.
Based user manual - https://mikrotik.com/product/audience#fndtn-downloads it can be configured with Winbox, for the default config, do reset.
Cool - but I don’t own one… thinking of building that setup from other MT hardware
Audience is just a standard MikroTik device with CAPsMAN setup and an extra 5GHz interface for linking to other Audiences. You can use it just like any other MikroTik device.
Good Morning
Is there anyone who can give me an export of the default config of the Audience?
I’m interested to see what it’s default config looks like.
Something like this:
script: #| Welcome to RouterOS!
#| 1) Set a strong router password in the System > Users menu
#| 2) Upgrade the software in the System > Packages menu
#| 3) Enable firewall on untrusted networks
#| 4) Set your country name to observe wireless regulations
#| 5) Set antenna gain on wireless interface
#| RouterMode:
#| * WAN port is protected by firewall and enabled DHCP client
#| * Wireless and Ethernet interfaces (except WAN port/s)
#| are part of LAN bridge
#| WPS Sync:
#| mode: ap-bridge;
#| wpa2: yes;
#| channel-width: 20/40mhz-XX;
#| LAN Configuration:
#| IP address 192.168.88.1/24 is set on bridge (LAN port)
#| DHCP Server: enabled;
#| DNS: enabled;
#| CAPsMAN:
#| bands: b/g/n, a/n, a/n/ac;
#| installation: indoor;
#| channel-width: 20MHz;
#| forwarding: local;
#| Wireless: CAP enabled on wireless interfaces
#| WAN (gateway) Configuration:
#| gateway: ether1 ;
#| ip4 firewall: enabled;
#| ip6 firewall: enabled;
#| NAT: enabled;
#| DHCP Client: enabled;
:global ssid;
:global defconfMode;
:log info "Starting defconf script";
# Apply configuration.
# these commands are executed after installation or configuration reset
:if ($action = "apply") do={
# wait for interfaces
:local count 0;
:while ([/interface ethernet find] = "") do={
:if ($count = 30) do={
:log warning "DefConf: Unable to find ethernet interfaces";
/quit;
:delay 1s; :set count ($count +1);
:local count 0;
:while ([/interface wireless print count-only] < 2) do={
:if ($count = 40) do={
:log warning "DefConf: Unable to find wireless interface(s)";
/ip address add address=192.168.88.1/24 interface=ether1 comment="defconf";
/quit
:delay 1s;
/interface wireless security-profiles {
add name=wpsSync
set wpsSync mode=dynamic-keys group-ciphers=aes-ccm unicast-ciphers=aes-ccm \
authentication-types=wpa2-psk disable-pmkid=yes wpa2-pre-shared-key=$defconfPassword comment=defconf
:local count 0;
:while ([/interface wireless find default-name="wlan3"] = "") do={
:if ($count = 15) do={
:log warning "DefConf: Unable to find wlan3 interface";
/quit
/interface wireless {
:local wl3 [find default-name="wlan3"]
:local wlanMac [get $wl3 mac-address];
:set ssid "SYNC-$[:pick $wlanMac 9 11]$[:pick $wlanMac 12 14]$[:pick $wlanMac 15 17]"
set $wl3 disabled=no mode=ap-bridge band=5ghz-a/n/ac ssid=$ssid security-profile=wpsSync wps-mode=push-button
set $wl3 channel-width=20/40mhz-XX
/interface list add name=WAN comment="defconf"
/interface list add name=LAN comment="defconf"
add name=bridge disabled=no auto-mac=yes protocol-mode=rstp comment=defconf;
:local bMACIsSet 0;
:foreach k in=[/interface find where !(slave=yes || type=wlan || name="ether1" || name~"bridge")] do={
:local tmpPortName [/interface get $k name];
:if ($bMACIsSet = 0) do={
:if ([/interface get $k type] = "ether") do={
/interface bridge set "bridge" auto-mac=no admin-mac=[/interface get $tmpPortName mac-address];
:set bMACIsSet 1;
:if (([/interface get $k type] != "ppp-out") && ([/interface get $k type] != "lte")) do={
add bridge=bridge interface=$tmpPortName comment=defconf;
/ip pool add name="default-dhcp" ranges=192.168.88.10-192.168.88.254;
add name=defconf address-pool="default-dhcp" interface=bridge lease-time=10m disabled=no;
add address=192.168.88.0/24 gateway=192.168.88.1 dns-server=192.168.88.1 comment="defconf";
/ip address add address=192.168.88.1/24 interface=bridge comment="defconf";
/ip dns {
set allow-remote-requests=yes
static add name=router.lan address=192.168.88.1 comment=defconf
/caps-man configuration {
add name=cfg-2ghz ssid=MikroTikE30BA6-2 channel.band=2ghz-b/g/n channel.control-channel-width=20mhz \
channel.extension-channel=XX distance=indoors installation=indoor \
datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes comment=defconf
add name=cfg-5ghz-ac ssid=MikroTikE30BA6-5 channel.band=5ghz-a/n/ac channel.control-channel-width=20mhz \
channel.extension-channel=XXXX distance=indoors installation=indoor \
add name=cfg-5ghz-an ssid=MikroTikE30BA6-5 channel.band=5ghz-a/n channel.control-channel-width=20mhz \
/caps-man provisioning {
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg-2ghz \
name-format=prefix-identity name-prefix=2ghz comment=defconf
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=cfg-5ghz-ac \
name-format=prefix-identity name-prefix=5ghz-ac comment=defconf
add action=create-dynamic-enabled hw-supported-modes=an master-configuration=cfg-5ghz-an \
name-format=prefix-identity name-prefix=5ghz-an comment=defconf
/caps-man manager interface {
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge comment=defconf
/caps-man manager set enabled=yes
/interface wireless cap set enabled=yes interfaces=wlan1,wlan2 caps-man-addresses=127.0.0.1 bridge=bridge
/ip dhcp-client add interface=ether1 disabled=no comment="defconf";
/interface list member add list=LAN interface=bridge comment="defconf"
/interface list member add list=WAN interface=ether1 comment="defconf"
/ip firewall nat add chain=srcnat out-interface-list=WAN ipsec-policy=out,none action=masquerade comment="defconf: masquerade"
/ip firewall {
filter add chain=input action=accept connection-state=established,related,untracked comment="defconf: accept established,related,untracked"
filter add chain=input action=drop connection-state=invalid comment="defconf: drop invalid"
filter add chain=input action=accept protocol=icmp comment="defconf: accept ICMP"
filter add chain=input action=accept dst-address=127.0.0.1 comment="defconf: accept to local loopback (for CAPsMAN)"
filter add chain=input action=drop in-interface-list=!LAN comment="defconf: drop all not coming from LAN"
filter add chain=forward action=accept ipsec-policy=in,ipsec comment="defconf: accept in ipsec policy"
filter add chain=forward action=accept ipsec-policy=out,ipsec comment="defconf: accept out ipsec policy"
filter add chain=forward action=fasttrack-connection connection-state=established,related comment="defconf: fasttrack"
filter add chain=forward action=accept connection-state=established,related,untracked comment="defconf: accept established,related, untracked"
filter add chain=forward action=drop connection-state=invalid comment="defconf: drop invalid"
filter add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN comment="defconf: drop all from WAN not DSTNATed"
/ipv6 firewall {
address-list add list=bad_ipv6 address=::/128 comment="defconf: unspecified address"
address-list add list=bad_ipv6 address=::1 comment="defconf: lo"
address-list add list=bad_ipv6 address=fec0::/10 comment="defconf: site-local"
address-list add list=bad_ipv6 address=::ffff:0:0/96 comment="defconf: ipv4-mapped"
address-list add list=bad_ipv6 address=::/96 comment="defconf: ipv4 compat"
address-list add list=bad_ipv6 address=100::/64 comment="defconf: discard only "
address-list add list=bad_ipv6 address=2001:db8::/32 comment="defconf: documentation"
address-list add list=bad_ipv6 address=2001:10::/28 comment="defconf: ORCHID"
address-list add list=bad_ipv6 address=3ffe::/16 comment="defconf: 6bone"
filter add chain=input action=accept protocol=icmpv6 comment="defconf: accept ICMPv6"
filter add chain=input action=accept protocol=udp port=33434-33534 comment="defconf: accept UDP traceroute"
filter add chain=input action=accept protocol=udp dst-port=546 src-address=fe80::/10 comment="defconf: accept DHCPv6-Client prefix delegation."
filter add chain=input action=accept protocol=udp dst-port=500,4500 comment="defconf: accept IKE"
filter add chain=input action=accept protocol=ipsec-ah comment="defconf: accept ipsec AH"
filter add chain=input action=accept protocol=ipsec-esp comment="defconf: accept ipsec ESP"
filter add chain=input action=accept ipsec-policy=in,ipsec comment="defconf: accept all that matches ipsec policy"
filter add chain=input action=drop in-interface-list=!LAN comment="defconf: drop everything else not coming from LAN"
filter add chain=forward action=accept connection-state=established,related,untracked comment="defconf: accept established,related,untracked"
filter add chain=forward action=drop src-address-list=bad_ipv6 comment="defconf: drop packets with bad src ipv6"
filter add chain=forward action=drop dst-address-list=bad_ipv6 comment="defconf: drop packets with bad dst ipv6"
filter add chain=forward action=drop protocol=icmpv6 hop-limit=equal:1 comment="defconf: rfc4890 drop hop-limit=1"
filter add chain=forward action=accept protocol=icmpv6 comment="defconf: accept ICMPv6"
filter add chain=forward action=accept protocol=139 comment="defconf: accept HIP"
filter add chain=forward action=accept protocol=udp dst-port=500,4500 comment="defconf: accept IKE"
filter add chain=forward action=accept protocol=ipsec-ah comment="defconf: accept ipsec AH"
filter add chain=forward action=accept protocol=ipsec-esp comment="defconf: accept ipsec ESP"
filter add chain=forward action=accept ipsec-policy=in,ipsec comment="defconf: accept all that matches ipsec policy"
filter add chain=forward action=drop in-interface-list=!LAN comment="defconf: drop everything else not coming from LAN"
/ip neighbor discovery-settings set discover-interface-list=LAN
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
# Revert configuration.
# these commands are executed if user requests to remove default configuration
:if ($action = "revert") do={
/user set admin password=""
/system routerboard mode-button set enabled=no
/system routerboard mode-button set on-event=""
/system script remove [find comment~"defconf"]
/ip firewall filter remove [find comment~"defconf"]
/ipv6 firewall filter remove [find comment~"defconf"]
/ipv6 firewall address-list remove [find comment~"defconf"]
/ip firewall nat remove [find comment~"defconf"]
/interface list member remove [find comment~"defconf"]
/interface detect-internet set detect-interface-list=none
/interface detect-internet set lan-interface-list=none
/interface detect-internet set wan-interface-list=none
/interface detect-internet set internet-interface-list=none
/interface list remove [find comment~"defconf"]
/tool mac-server set allowed-interface-list=all
/tool mac-server mac-winbox set allowed-interface-list=all
/ip neighbor discovery-settings set discover-interface-list=!dynamic
:local o [/ip dhcp-server network find comment="defconf"]
:if ([:len $o] != 0) do={ /ip dhcp-server network remove $o }
:local o [/ip dhcp-server find name="defconf" !disabled]
:if ([:len $o] != 0) do={ /ip dhcp-server remove $o }
/ip pool {
:local o [find name="default-dhcp" ranges=192.168.88.10-192.168.88.254]
:if ([:len $o] != 0) do={ remove $o }
:local o [/ip dhcp-client find comment="defconf"]
:if ([:len $o] != 0) do={ /ip dhcp-client remove $o }
/ip dns {
set allow-remote-requests=no
:local o [static find comment="defconf"]
:if ([:len $o] != 0) do={ static remove $o }
/ip address {
:local o [find comment="defconf"]
:foreach iface in=[/interface ethernet find] do={
/interface ethernet set $iface name=[get $iface default-name]
/interface bridge port remove [find comment="defconf"]
/interface bridge remove [find comment="defconf"]
/interface bonding remove [find comment="defconf"]
/interface wireless cap set enabled=no interfaces="" caps-man-addresses=""
/interface wireless reset-configuration wlan1
/interface wireless reset-configuration wlan2
/interface wireless security-profile set default mode=none\
authentication-types="" disable-pmkid=no wpa2-pre-shared-key="" comment=""
/interface wireless reset-configuration wlan3
/interface wireless security-profiles remove [find name="wpsSync"]
/caps-man manager set enabled=no
/caps-man manager interface remove [find comment="defconf"]
/caps-man manager interface set [ find default=yes ] forbid=no
/caps-man provisioning remove [find comment="defconf"]
/caps-man configuration remove [find comment="defconf"]
:log info Defconf_script_finished;
:set defconfMode;
:set ssid;
caps-mode-script: #-------------------------------------------------------------------------------
# Note: script will not execute at all (will throw a syntax error) if
# dhcp or wireless-fp packages are not installed
#| CAP configuration
#| Wireless interfaces are set to be managed by CAPsMAN.
#| All ethernet interfaces and CAPsMAN managed interfaces are bridged.
#| DHCP client is set on bridge interface.
# bridge port name
:global brName "bridgeLocal";
:global logPref "defconf:";
:global action;
:log info $action
# wait for ethernet interfaces
:local count 0;
/quit;
:delay 1s; :set count ($count + 1);
:local macSet 0;
:local tmpMac "";
:foreach k in=[/interface ethernet find] do={
# first ethernet is found; add bridge and set mac address of the ethernet port
:if ($macSet = 0) do={
:set tmpMac [/interface ethernet get $k mac-address];
/interface bridge add name=$brName auto-mac=no admin-mac=$tmpMac comment="defconf";
:set macSet 1;
# add bridge ports
/interface bridge port add bridge=$brName interface=$k comment="defconf"
# try to add dhcp client on bridge interface (may fail if already exist)
:do {
/ip dhcp-client add interface=$brName disabled=no comment="defconf"
} on-error={ :log warning "$logPref unable to add dhcp client";}
# try to configure caps (may fail if for example specified interfaces are missing)
:local interfacesList "";
:local bFirst 1;
# wait for wireless interfaces
:while ([/interface wireless find] = "") do={
:log warning "DefConf: Unable to find wireless interfaces";
/quit;
# delay just to make sure that all wireless interfaces are loaded
:delay 5s;
:foreach i in=[/interface wireless find] do={
if ($bFirst = 1) do={
:set interfacesList [/interface wireless get $i name];
:set bFirst 0;
} else={
:set interfacesList "$interfacesList,$[/interface wireless get $i name]";
:do {
set enabled=yes interfaces=$interfacesList discovery-interfaces=$brName bridge=$brName
} on-error={ :log warning "$logPref unable to configure caps";}
:do {
set enabled=no interfaces="" discovery-interfaces="" bridge=none
} on-error={ :log warning "$logPref unable to unset caps";}
wps-sync-mode-script: #-------------------------------------------------------------------------------
#| WPS Sync Configuration:
#| * Wireless and ethernet interfaces bridged with enabled DHCP client
#| * wlan1/2 access points and wlan3 wps sync repeater
#| Wireless: CAP enabled on wlan1/2
#| WPS Sync:
#| mode: repeater;
#| DHCP client: enabled;
# bridge port name
:global ssid;
:global action;
:log info $action
:local count 0;
/quit;
:local macSet 0;
:local tmpMac "";
:set macSet 1;
# add bridge ports
:do {
:local count 0;
:while ([/interface wireless print count-only] < 3) do={
/quit
:delay 1s;
:foreach k in=[/interface wireless find] do={
# add bridge ports
:local hwInfo [/interface wireless info hw-info [.. find where default-name="wlan3"] as-value];
#:if (($hwInfo->"locked-countries")~"russia") do={
/interface wireless set [find where default-name="wlan3"] channel-width=20/40mhz-XX band=5ghz-a/n/ac
#} else={
# /interface wireless set [find where default-name="wlan3"] channel-width=20/40/80mhz-XXXX band=5ghz-a/n/ac
set discovery-interfaces=bridgeLocal enabled=yes interfaces=wlan1,wlan2
/interface wireless
setup-repeater wlan3 duration=2m
/interface wireless cap set enabled=no interfaces="" discovery-interfaces=""
:set brName;
:set logPref;
:set ssid;
Perfect
Thank you very much
ditto - thanks for that - going to try and do with with Netmetal with two AC cards installed.
