authentication sequence for login
I have managed to use Radius for user authentication. I relaized that the local user is working in parallel to the Radius users. Is there a way to just allow the local user in case Radius server is not reachable? Local user is in our case an emergency user if Radius is not reachable. If Radius is reachable it should be first choice because of personalized users. I just know it from Nokia or Cisco to be able to configure the authentication order and would like to setup the MT in the same way. Any information appreciated.
Thx
Richard
no one using Radius for authentication and only local users as fallback?
Regards Richard
Use search function before starting again another topic for the same thing:
http://forum.mikrotik.com/t/feature-request-allow-local-user-only-if-radius-is-down/158845/1
Thanks. Did not find this. hoped that there is a way to define the priority of authentication/authorization methods but good to know that there is a workaround to achieve a similar behavior.
Thank you
regards Richard
