krtko
January 15, 2009, 6:30am
1
hello,
i use mikrotik 3.x for dhcp server with static leases, sometimes i get status busy on some static entries, i tryed this script to check and repair it, but it does not work for me
/ip dhcp-server lease;
:foreach i in=[/ip dhcp-server lease find status=busy]\
do={
:log error ("Busy status detected: " . [/ip dhcp-server lease get $i address]);
/ip dhcp-server lease disable $i;
/ip dhcp-server lease enable $i;
script do not find any busy status in static lease list.
thanks for any idea.
BR
krtko
kryseck
February 25, 2009, 10:30am
2
Hi!
Revome 1ª line “/ip dhcp-server lease;” .
do={
is this right??
i have tried it but it wont work…
tnx
bye
Try to use quotation marks “busy”
:foreach i in=[/ip dhcp-server lease find status=“busy”]
do={
or simply like I do
do={
/ip dhcp-server lease check-status $i;
lukasPL:
do={
or simply like I do
do={
tnx for the answer…now the script is working but i will first test it when some lesses are busy..
you’r script is not god for me…because i don’t have someone to look everyday the log-file…
tnx
bye
I had the same issue.
At my network problem solved… One of Mikrotik’s had PROXY-ARP on ether2 and when host trying to get IP from DHCP (static leases in my case) he thinks that this specific IP is already used.
DISABLE PROXY-ARP on every MT.
:foreach i in=[/ip dhcp-server lease find status="busy"]\
do={
Why it does not work on my MT3.30?
there are slight syntax changes between version 3 and 4.
best shot is, in console open script editor and paste script there, use F5 to refresh mark-up of text. After error there should not be any mark-up.
Thanks !!! Script works perfect!
do={
I added it to a scheduler once per hour. And it works without my attention
