i have a problem to let any one connet to my hotspot to automaticlly go to my hotspot page.
what is going on is when some one connect to the hotspot he must be go to the browser open it and write the exact name
of my hotspot page *www.redhat.com * so he can get the login page
i tried to change the login by tab in hotspot server profile > tab login
Not all devices do this. Apple devices and windows machines will try accessing a website after connecting to a network. If the site doesn’t come up as expected, it displays your redirected login page. Windows has a pop-up that additional details may be required.
So ensure the issue isn’t being caused by your device. Android never does, for example.
sorry for late responding i give up because my topic was not published
no the issue is about the indroid devices, i start my network and my purpose is the indroid users, but they having a hard time
to use the network via hotspot because they dont know what to do after connect to my network, they just keep saying there is no internet and i always said to them you have to open ur brwoser and put your card information in.
so there is no kind of script, code or anything that could redirect them to my network login page
note: i reinstall my microtik very well and now when a device connect to the network in some devices there is a pop-up tells u its a hotspot and when u press on that its open to u the login page, but the problem its not in all indroid devices only the expensive ones like NOTE or S family.
Welcome to Android. The later versions of their OS may do as you’ve indicated. Older devices – which cannot be updated will never have a fix. You need to have instructions provided when they are provided with a login which is no good if your connecting customers are only learning about the hotspot when scanning for networks on their devices rather than say buying a login ticket through reception.
sorry again for late responde
internet here is hell and so expensive
any way thank u for responding MadEngineer u was helpfull
its okay now customers start to learn how to do it and some new indroid devices give is a pop-up message that is the network u connect to is a hotspot and need login information.
i was hope there is any way to redirect them to hotspot login page. but its okay like that.
