Automatically added after ROS update?
Hi everyone,
I had the following added to my config automatically after updating ROS
#2025-06-21 22:25:51 by RouterOS 7.19.2
/ip ipsec profile
and also the following policy
I cannot delete this so-called “template”.
Did this occur to you as well?
Should I disable this?
Those default values have been changed with the upgrade to 7.16. Our user @tangent has documented such modifications of the default parameter values on his page:
MikroTik Solutions: Configuration Flotsam
On that page you’ll also get the suggested commands to reset the parameters to their default values, so that they no longer appear in the setting export.
/ip ipsec profile
set [ find default=yes ] dpd-interval=8s dpd-maximum-failures=4
Thanks a lot mate, this was exactly what I was looking for!
ok stupid follow up question, how do I mark this thread as resolved in this new view? This new view looks nice, biut its not overly intuitive :laughing:
