Average Rate Queue Tree
Hello guys, just want to ask why my Average Rate from Queue Tree sometime didnt load the video im watching, which making my video buffering
i set it at 8mbps but the average only doing around 190kb, but usually if its good the average around 1-2mbps
do i need to set something?
8 Mbps isn’t enough for 4K and the lower limit for HD. Without knowing how your queue was implemented, if mangle is used and where you’re streaming from, how can we help you ? If you’re streaming online, do a trace route. Packets aren’t queued if the limit isn’t reached, so it has no effect on traffic. Also check if the stream works with the default FastTrack rule to rule out a bad configuration.
