Feature Request: Back to Home “LAN ONLY” users!
The Back to Home feature is awesome, and I have been using it a lot.
Most of the time, I use it to access the local network for the remote router (Have “Allow LAN” enabled) to support, check, or connect to something there. Often, my own WAN connection is better than the remote connection, so I’d prefer to use my own WAN connection in these circumstances.
So, I’d like to request a configuration option for “LAN ONLY”. I already do this successfully by manually changing the WireGuard configuration for AllowedIPs on the Peer… but it would be excellent if this was an easy check box.
Thank you!
