backup link
HI
guys i have 1 uplink llink with 2 downlink services each one entering by an interface to my main mikrotik
ether 2 is on a flat rate cir downlink
ehter 3 is on a per traffic cir backup
i need mikrotik to check the internet on the flat rate servcie and if it is down for 5 min to switch to the second one until the first is up again
(i will mkae 2 static routes for each service )
can it be done ? using a script that check te firss gateway by ping or something when it is down use the other route until first is up ?
