Bandwidth test logging
Hi there,
I have an opportunity to sell some MT boxes to a major customer who wants to bandwidth test ethernet transmission circuits.
MT loaded on some embedded PC boards would be perfect.
Using Winbox I can see “live traffic” on the ethernet port and use the bandwidth testers on the box to generate/receive traffic.
Does anyone have a script to regularly (every 5 minutes) send a “throughput report” to any external store (email, FTP, or just append to a logfile)
(Apologies I am a scripting newbie, an expert will tell me this is obvious)
Would greatly appreciate help, preferably an example
Many thanks
example using e-mail!
here i'm checking transmitted data rate to address 1.1.1.1
/system script add name=bandtest source={
:global i
/tool bandwidth-test 1.1.1.1
direction=transmit
duration=14s
do={
:if ($status="running") do={
:set i $tx-current
/system scheduler add name=send_mail on-event=bandtest interval=5m disabled=no
Edgars
Hi Edzix
Thanks for the tip - this doesn’t look totally complete, there is no e-mail tool call - where do I put that?
Thanks for the help so far -
Regards
Stephen
yes, sorry, my mistake. Here is the correct one:
:global i
direction=transmit
duration=14s
do={
:if ($status=“running”) do={
:set i $tx-current
:delay 15s
/tool e-mail send to receiver@somehost.com subject=“Bandwidth test results” body=("Transmitted bytes/s: " . $i)
