Hi to all,
I have internet interface of routeros connected at internet at 20 Mbps in download.
In another interface I have my lan.
I would to devide equally the bandwith at users but limiting total bandwith at 10 Mbps and not 20.
In which way is it possible ?
Certainly with queues but I had some difficults.
Can you help me?
what difficulties do you have? =)
in general, you should create PCQ queue with Rate=0 and max-limit=10M
Can you add routeros command?
http://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
just set pcq-rate=0 and max-limit=10M
Then I created two pcq queues in this way:
/queue type add name=“PCQ_download” kind=pcq pcq-rate=0 pcq-classifier=dst-address pcq-limit=10M
/queue type add name=“PCQ_upload” kind=pcq pcq-rate=0 pcq-classifier=src-address pcq-limit=512K
then I added queues tree:
/queue tree add parent=global-in queue=PCQ_download packet-mark=all
/queue tree add parent=global-out queue=PCQ_upload packet-mark=all
But this is only if you mark packet with mangle.
I dont’ want to use mangle.
Can you help me?
then create simple queue with those queue types
p.s. you may use packet-mark=no-mark
Then now I have :
/queue simple add queue=PCQ_Download/PCQ_Upload target-addresses=10.0.0.0/8
I specified 10.0.0.0/8 because my lan have this address plane.
It’s all correct?
There is a way to verify that queue is running and bandwith is divided equally to lan users?
see queue stats =)
also, add max-limit=10M to queue definion =)
What is difference beetween pcq-limit parameter and max-limit ? I specified only max-limit…
There are some packet dropped in the queue… what it means?
all answers to basic questions are here: http://wiki.mikrotik.com/wiki/Manual:Queue
for example, ‘pcq-limit’ is number of packets ![]()
