I want to power the RB4011iGS+RM router with the DC power connector from a DC power plant. I would rather not cut the barrel connector off of the supplied PSU - does anyone have the specs I need for this connector so I can order them for this purpose?
Thanks!
[Edit] I found in the user manual that is says it is a 5.5 mm outside and 2 mm inside connector - female, pin positive plug. But, to clarify - when searching sources for this - I am seeing MANY 5mm outside with 2.1mm inside connectors (and so far no 2mm). Can anyone confirm if these are a match (2mm vs 2.1mm) or do I need to make sure it is 2mm exactly?
