Now following this guide https://wiki.mikrotik.com/Manual:The_Dude_v6/Installation
I downloaded provided all packages and pulled out dude-7.19.1-mmips.npk
Uploaded that npk file to the router through GUI in Files and then I can see dude-7.19.1-mmips.npk listed there.
Told the router to reboot in GUI, it does so and beeps on the way up.
Problems;
I don’t see Dude in the GUI menus
Doesn’t seem to be available to enable in CLI either, see below.
The npk file I uploaded above is gone.
Now what? Is there a step or something I’m missing in the guide?
[admin@RouterOS] > /dude
bad command name dude (line 1 column 2)
[admin@RouterOS] > /dude set enabled=yes
[admin@RouterOS] > /disk print
Flags: B - BLOCK-DEVICE; M - MOUNTED
Columns: SLOT, MOUNT-POINT, MODEL, SERIAL, INTERFACE, SIZE, FREE, USE, FS, FS-LABEL
# SLOT MOUNT-POINT MODEL SERIAL INTERFACE SIZE FREE USE FS FS-LABEL
0 BM usb1 usb1 Generic Mass Storage 977C146E USB 2.00 480Mbps 16 106 127 360 15 854 936 064 0% fat32 MAGNUM
You can go to System > Packages, use “Check for Updates”, the check the “dude” package, hit “Apply”. That will install the right dude for your system - but this will only work in 7.19+.
If you’re out of disk space, that could be a problem. But I’d try above, then check the logs after the reboot caused by “Apply”.
You may also need to set the directory to use, once the command appears, like:
/dude/set data-directory=usb1/dude
OK, good catch, system packages does now say 7.19.1 is available. Could have sworn it said no further updates available yesterday when I did these updates, was on 6 something. Also didn’t realize an exact match was required.
And thanks for the tip on the drive switch required.
And I recall 7.19.0 had some bug with Dude, so good you upgraded. But package version do have to match exactly… but the “extra package selector” is new 7.19 - but that align extra-package automatically in future.
