the IPsec VPN config from the manuals application example (http://www.mikrotik.com/docs/ros/2.9/ip/ipsec.content#5.44.8.2) is not working for me, the packets are discarded
scenario is very basic:
LAN - 10.10.1.1/24-(R1)-x.y.z.157 - DSL - x.y.z.160-(R2)-10.10.5.1/24 - LAN
config of router 1
/ ip firewall nat
add chain=srcnat src-address=10.10.1.0/24 dst-address=10.10.5.0/24 action=accept comment="" disabled=no
add chain=srcnat out-interface=t-dsl-business action=masquerade comment="" disabled=no
/ ip ipsec policy
add src-address=10.10.1.0/24:any dst-address=10.10.5.0/24:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=yes sa-src-address=x.y.z.157 sa-dst-address=x.y.z.160 proposal=default \
manual-sa=none dont-fragment=clear disabled=no
/ ip ipsec peer
add address=x.y.z.160/32:500 secret="qwertzuiopasdfghjkl" generate-policy=no exchange-mode=aggressive \
send-initial-contact=yes proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 \
lifetime=1d lifebytes=0 disabled=no
/ ip ipsec proposal
add name="default" auth-algorithms=md5 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 \
disabled=no
config of router 2
/ ip firewall nat
add chain=srcnat src-address=10.10.5.0/24 dst-address=10.10.1.0/24 action=accept
/ ip ipsec policy
add src-address=10.10.5.0/24:any dst-address=10.10.1.0/24:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=yes sa-src-address=x.y.z.160 sa-dst-address=x.y.z.157 proposal=default \
/ ip ipsec peer
add address=x.y.z.157/32:500 secret="qwertzuiopasdfghjkl" generate-policy=no exchange-mode=aggressive \
/ ip ipsec proposal
disabled=no
tested with ping from both ends
router 1:
/ping 10.10.5.1 src-address=10.10.1.4
11:40:00 ipsec,ike,info initiating phase 2 (src x.y.z.157) (dst x.y.z.160)
11:40:00 ipsec,info ipsec packet discarded: src=10.10.1.4 dst=10.10.5.1
11:40:00 ipsec,ike,info received ISAKMP packet from x.y.z.160:500, phase 2, Quick
11:40:01 ipsec,info ipsec packet discarded: src=10.10.1.4 dst=10.10.5.1
11:40:02 ipsec,info ipsec packet discarded: src=10.10.1.4 dst=10.10.5.1
11:40:03 ipsec,info ipsec packet discarded: src=10.10.1.4 dst=10.10.5.1
router2:
/ping 10.10.1.4 src-address=10.10.5.1
10:39:00 ipsec,ike,info initiating phase 2 (src x.y.z.160) (dst x.y.z.157)
10:39:01 ipsec,ike,info received ISAKMP packet from x.y.z.157:500, phase 2, Quick
10:39:01 ipsec,info ipsec packet discarded: src=10.10.5.1 dst=10.10.1.4
10:39:02 ipsec,info ipsec packet discarded: src=10.10.5.1 dst=10.10.1.4
under ip ipsec installed-sa only the direction=in-SA is established on both routers.
anyone an idea? do i overlook somthing obvious?
TIA.
