Hello together,
I want to use my CRS226-24G and VLANs, but I have a general question and hope you can help.
In the VLAN-guides there are always a minimum of 2 devices displayed, a switch and a router, but as my CRS has already 24 ports I want to know if it’s possible to use a single device like the CRS226 for routing and switching the VLANs without having a second switch/router?
Is this possible? If yes, how would you start configuring the CRS?
TIA and Regards
Martin
Network setup should look like this:
VLAN 100 - Media devices (TVs…)
VLAN 200 - Home devices (home automation, Home devices with internet / app access)
VLAN 300 - Computers
VLAN 400 - Servers or similar which should be accessed through different VLANs
VLAN 99 - management VLAN
There should be tagged and untagged Ports and also a Trunk to my Access-Point which can handle VLANs (to divide wireless devices), Access to internet itself is provided using a “Fritzbox” via Ethernet on eth1.
The goal is to divide the different devices and set up rules and a Firewall to block access from one VLAN to another.
