Hi, I have a HEX router that send Vlan 100 + Untag traffic to a PowerBox Pro in Bridge mode on Eth1. I want Vlan to be Untag on Eth3.
How to configure the PowerBox Pro to do So?
Thx!!!
Thx!!!
Did you even try to configure it yourself ? If yes then please post your configuration here.
There is a dedicated page on this topic:
https://help.mikrotik.com/docs/display/ROS/Basic+VLAN+switching#BasicVLANswitching-Otherdeviceswithabuilt-inswitchchip
Here’s the config that does’t work… Incoming traffic from a HEX router to this PowerBox acting as a switch on Eth1 with V100 tag and need to untag at ether3-PTP… What needs to be done? Thx!
add ingress-filtering=yes name=bridge1 vlan-filtering=yes
add bridge=bridge1 interface=ether3-PTP
add bridge=bridge1 interface=sfp1
/interface bridge vlan
add bridge=bridge1 tagged=ether1 untagged=ether3-PTP vlan-ids=100
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3-PTP list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
You are only sending 1 VLAN to this powerbox ? Why is your trunk port in WAN list on device you are using as a switch ?
Can you show config from your device that is used as a router ?
I’m sending vlan 100 and other untag traffic to powerBox on Eth1. Here is the config from HEX router sending packets:
/interface vlan
add interface=ether1 name=v.100.e5.BH vlan-id=100
add address=10.1.37.1/29 interface=v.100.e5.BH network=10.1.37.0
/routing ospf interface-template
add area=ospf-area-1 cost=30 disabled=no interfaces=ether1 networks=
10.1.37.0/29 type=ptp
There is no need to quote previos post and please DO use proper formatting tags for code.
