Batch script
does anyone have batch or vbscript to login on multiple IPs and send specified command?
Something like to login on machine where is ip from ip.txt and send cmd.txt to machine…
Thank You in advance!
If you are using V3 you can grab one of the API scripts from the WIKI.
http://wiki.mikrotik.com/wiki/Category:API
-Louis
Did you ever find a batch file or vbscript? I am looking for one to do the same thing…
