battling with limewire :))
heloo people
all p2p block except limewire how can we block this? i doubt that this limewire using encrypted p2p data, it is possible to block in web-proxy? can anyone give some tips :slight_smile:
thanks
I think Butch’s script catches Limewire from the number of open connections.
should be easy for someone to recommend something like that or go to www.butchevans.com
I’ll take that back: just tested it and it does not pick up Limewire but it does pick up Vuze right away.
thanks for reply wis, damn this thing eat a lot of banwid hehe :slight_smile:)
Apparently it uses TCP ports 6346-6347, but maybe that was true in old versions. The best thing to do, is to allow only known ports and protocols, and block everything else.
