How can it be a script that indicates via small-beep access to hotspots in hotel?
The problem is how to determine the fact of hotspot access.
For example, you can use
/tool traffic-monitor
which will fire an event based on current traffic volume passed through hotspot interface. Event handler will do all dirty work - blinks, beeps or something else.
I’m not sure if this is what you want, but here it is
/ip hotspot user profile set 0 on-login=":beep"
Whenever new user logs in you will hear a beep.
Wow! Thanks.
Tank mrz,
SUPER.
set default idle-timeout=none keepalive-timeout=2m name=default on-login=“:beep length=1s frequency=5000”
on-logout=“:beep length=3s frequency=500” shared-users=1 status-autorefresh=1m transparent-proxy=no
Or send e-mail or sms for confirmation!
