Beginner: Local + Guest network (VLAN)
Could you please help me with guest network VLAN configuration?
I have 3 devices:
Core router RB3011 (for example 192.168.1.1), Switch CRS326 (192.168.1.10) and Acess point hAP (192.168.1.15).
I’ve configured hAP as access point and have a local WiFi network in use.
Now I wan’t to configure one more wireless network for guests, with isolation to local network.
What I have done:
Created VLAN on wireless router - on ether1 (vlan-guest, ID=20) , Virtual wlan on wlan1 (wlan-guest, ID=20, VLAN Mode= use tag).
Created bridge on wireless router (guest-bridge) connected vlan-guest and wlan-guest to it.
Created VLAN on switch master port ether1 (vlan-guest, ID=20).
Created VLAN on core router at ether2 (switch master port) (vlan-guest, ID=20).
Created Address on guest-vlan interface (10.1.1.1/24 for example)
Configured DHCP pool for guest-vlan interface.
At this moment guest Wifi network is visible but client didn’t receiving any IP address, configuring static ip adress (10.1.1.20/24 with gw: 10.1.1.1 dns: 8.8.8.8 ) doesn’t provide connection as well.
Thanks in advance.
Hi
As I understand it (https://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#VLAN_tagging) you don’t need vlan definition on wAP or CRS: they will just pass through (so without vlan filtering).
You DO have to define a vlan interface on router (3011) assign IP and forward/masq traffic as you wish.
The wiki documentation does not indicate how the VLAN tag relates to the bridge and how configure with version 6.41 bridge VLAN implementation. An example may be useful
Tranks
Yeah, if some one could post example configuration will be good.
I’ve disabled VLAN definitions on CRS, and leave only VLAN on wireless interface.
I was trying to make configuration from this post - http://forum.mikrotik.com/t/office-wifi-guest-and-internal-networks/73519/1
