UDP Traffic is just sent their is no checking between the sender and receiver acknowledging order or receipt, it has a lower overhead on traffic due to that runs slightly faster(Bandwidth utilisation) because of no resending or waiting for acknowledgments, also has fast ‘ping’ times due to no error checking.
TCP traffic like http, ftp, smb, nfs, iscsi acknlwedge the receipt of packets and ensure that the first sent packet arrives first. TCP traffic also calculates hashes like md5 to ensure that the packet is completely uncorrupted from its trip. The result of this checking receipting and calculating is that the traffic is highly resilient to packet loss and out of order arrival from traversing a Wide area network, with individual packets taking different paths to the destination. This makes TCP the prime transport protocol for information accuracy after a network transmission.
OpenVPN Encapsulates a packets in an encrypted container to be sent to the receiving server decrypted and sent to the specified receiver on the other end. In TCP mode openvpn encrypts the original packet making it unreadable to all but the receiving server, and transmits the encrypted packet with all the tcp headers to the recipient server. That server will then work out if any packets are missing or out of order or corrupted using the TCP techniques. Once it is satisfied that the packet is correct it will decrypt and transmit that packet to the receiving client. That client will then the overwhelming majority of the time check that received packet with TCP techniques, because most protocols in networking are TCP. The client will attempt to authenticate by sending acknowledgment packets and by this stage we will have worked out that the packets is correct twice with by acknowledging twice (Doubling the acknowledgment bandwidth more if acknowledgment packets are lost). ensured that the order is correct twice and ensured that no packets are corrupted twice. You will also have ensured accuracy in packets that are not meant to be assured of accuracy due to need of faster receiving times (UDP), thus removing the original advantage of UDP.
OpenVPN UDP encapsulates a packet in an encrypted container with UDP header and protocols. The packet is received by the server, its is decrypted and forwarded to the intended recipient. That recipient processes it like any other normal packet if it is TCP it will ensure accuracy, if UDP just read the packet, it will also process ICMP (Ping) with more accurate times due to less time lost in ensuring accuracy.
As I believe I explained UDP openVPN still ensures packet accuracy on the protocols that require it because they do it themselves. However, I also demonstrated that TCP openVPN wastes bandwidth and resources checking already checked packets for accuracy, whilst checking packets that are not required to be checked also wasting bandwidth.
I prefer the OpenWRT Implementation better due to UDP support, and My Ability to use detailed commands such as client config directories, etc.
Let me know if this is not clear.
Edit: In my opinion the only reason that you would use tcp openVPN is so that it can be operated behind a http proxy server.
