Not sure if this is more of a wireless or a routing question, thought I’d start here. I have virtual APs for the guest network, and devices I don’t fully trust - IoT gadgets etc. Each AP has its own interface, IP range and DHCP server, but devices on different APs can still access each other. What’s the best way to completely isolate the virtual APs?
Routing rules
VLANs
Firewall rules
something else?
In WebFig, under IP >> Routes, each Virtual AP interface appears to have some sort of default route associated with it, the status is ‘dynamic, active, connected.’ Can I disable those, and would it have the desired effect?
Also add CAPsMAN central delivery (creates a CAPWAP tunnel to each wireless interface) to your list with options.
Or other tunnel and VXLAN, can replace VLAN as separator. Something like this … https://www.youtube.com/watch?v=9JYv2nsaL4w&t=9s … MikroTik PPPoE and Hotspot over VXLAN
@holvoetn, that guide certainly is impressive! I’m digging in now
@bpwl, I appreciate your suggestions, if I’m being honest they all went over my head I would like to learn about bridge port horizons, switch port isolation, HW offloading, CAPWAP tunnels, and especially VXLANs in the future!
One more question, if anyone’s up for it. VLANs are a layer 2 thing - what about layer 3? Each vAP has its own subnet, why couldn’t I simply prevent the router from routing between them?
I thought CAPsMAN was a tool for managing multiple physical APs in a centralized fashion.. are there any advantages to using it to manage multiple virtual APs on a single router?
