I have the above setup for a small SOHO / home setup. The RB 750G r3 has the two RB wAP G-5HacT2HnD attached in bridge mode as access points so that the WLAN spans over the whole area of the house. Access is via the RB 750G r3 for LAN-based clients and via the two RB wAP G-5HacT2HnD for WLAN-based clients.
I have several devices which should have restricted access times. Other devices on the network should have no restrictions. What is the easiest way to implement access lists? The clients in question could connect to each access point. I don’t want to duplicate everything I do on one AP on the other, is there a better way?
Also, a side issue, if I set the time restriction for a wireless access point from “23:00:00” to “1d 05:00:00”, does it really roll over to the next day, or do I need to seperate times from 23:00:00 to 23:59:59 and from 00:00:00 to 05:00:00? Couldn’t find anything for the pre-filled “1d” in the wireless acess list fields.
