Hello.
My question is: is it possibile to setup MPLS/VPLS between my mikrotik routers having BGP as dynamic routing protocol instead of OSPF?
Hello.
To clarify the question: Is it possible to redistribute LDP with BGP and avoid OSPF ?
Regards,
Thanos
Yes. All that’s needed is a routed infrastructure - the protocol used is irrelevant.
Nope.
LDP explicitely do not use bgp routes to distribute lables.
All routes excepg the bgp could be used, i.e. ospf.
Interesting, I suggest you test it.
I agree with Barkas. However, the wiki ( http://wiki.mikrotik.com/wiki/Manual:MPLSVPLS ) clearly states that LDP by default distributes labels for active IGP routes (that is - connected, static, and routing protocol learned routes, except BGP).
I added the loopback address (/32) to the bgp networks and the vpls tunnels established successfully, routeros >= 6.19
Topology (all routerOS):
A – B – C
A – B: eBGP
B – C: eBGP
A – C: VPLS tunnel
Regards,
Thanos
I did think a colleague of mine had it running this way.
A,B, C have same AS?
No, different.
I tried your configuration but vpls does not esthablish, routes dinstributed by bgp are not used by ldp in my case
