Nothing needs to be done. Configure your router with your 4-byte ASN. Your peer will configure the session toward you with remote-as=23456. You will use their regular AS in remote-as=. BGP will bring up the session, and your upstream will see your AS as the 4-byte transitional ASN. The rest of the world which support 4-byte ASN’s will see your real ASN in the path.
