Using RouterOS v7.2.3 BGP we are having a problem with the default route obtained from our upstream provider showing up in the route table as Invalid (DIFb).
The BGP session is established as shown below.
Flags: E - established
0 E remote.address=50.xxx.xxx.225 .as=1xxx2 .id=198.xxx.xxx.102 .refused-cap-opt=no .capabilities=mp,rr,gr,as4,llgr .hold-time=1m30s .messages=135 .bytes=2609 .gr-time=120 .eor=ip
local.address=50.xxx.xxx.226 .as=3xxxx5 .id=10.219.250.1 .capabilities=mp,rr,gr,as4 .messages=126 .bytes=2423 .eor=""
output.procid=62 .filter-chain=out-CSpire .network=bgp-networks
input.procid=62 .filter=in-CSpire ebgp
hold-time=1m30s keepalive-time=30s uptime=1h2m2s
Our settings for BGP are below. The BGP settings are from doing an upgrade from 6.45.9 to 7.2.3.
This all worked in RouterOS v6.
/routing bgp connection
add as=3xxxx5 cisco-vpls-nlri-len-fmt=auto-bits connect=yes disabled=no input.filter=in-CSpire listen=yes local.address=50.xxx.xxx.226 .role=ebgp name=Cspire output.filter-chain=out-CSpire .network=bgp-networks remote.address=50.xxx.xxx.225/32 .as=1xxx2 .port=179 router-id=10.219.250.1 routing-table=main
We have two small blocks of public IP addresses that we rent from our upstream provider. A /27 and a /28.
We also have our own /24 public IP block that we obtained recently from ARIN.
Routing Filters:
add chain=in-CSpire comment="ACCEPT DEFAULT ROUTE" disabled=no rule="if (dst in 0.0.0.0 && dst-len == 0) { accept; }"
add chain=in-CSpire comment="DROP ALL OTHER ROUTES" disabled=no rule="if (dst in 0.0.0.0/0 && dst-len in 0-64) { reject; }"
add chain=out-CSpire comment="ONLY ADVERTISE THESE ROUTES" disabled=no rule="if (dst in 173.xxx.xxx.0/27 && dst-len == 24) { accept; }"
add chain=out-CSpire comment="ONLY ADVERTISE THESE ROUTES" disabled=no rule="if (dst in 173.xxx.xxx.144/28 && dst-len == 24) { accept; }"
add chain=out-CSpire comment="ONLY ADVERTISE THESE ROUTES" disabled=no rule="if (dst in 45.xxx.xxx.0/24 && dst-len == 24) { accept; }"
Address List:
add address=45.xxx.xxx.0/24 list=bgp-networks
add address=173.xxx.xxx.144/28 list=bgp-networks
add address=173.xxx.xxx.0/27 list=bgp-networks
We added a static default route to keep everything working while we tested BGP. The default route obtained from our upstream provider is exactly the same as our static default route except it shows as invalid.
Static Routes:
add comment="STATIC ROUTE TO C-SPIRE TOWER" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=50.xxx.xxx.225 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add blackhole disabled=no distance=1 dst-address=173.xxx.xxx.0/27 gateway="" pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add blackhole disabled=no distance=1 dst-address=173.xxx.xxx.144/28 gateway="" pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add blackhole disabled=no distance=1 dst-address=45.xxx.xxx.0/24 gateway=0.0.0.0 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
How can we make the default route obtained by BGP show up as a valid route?
