I a trying to do BGP peering with two bandwidth providers, according to example RouterOS - RouterOS - MikroTik Documentation en el setup que se llama “Load Sharing”.
My problem is one of the dynamic obtained routes is inactive
/ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
2 ADb 0.0.0.0/0 12.250.170.117 20
5 Db 0.0.0.0/0 50.84.34.213 20
Number 5 is NOT ACTIVE ... WHY? --- Attached screenshot .
Here's my conf, can you please help pointing me in the right direction?
/routing bgp instance
set default as=13959 client-to-client-reflection=no comment="Autophone of Laredo" disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-con
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing bgp network
add disabled=no network=216.150.33.0/24 synchronize=no
add disabled=no network=216.150.32.0/24 synchronize=no
add disabled=no network=216.150.34.0/24 synchronize=no
add disabled=no network=216.150.35.0/24 synchronize=no
add disabled=no network=216.150.36.0/24 synchronize=no
add disabled=no network=216.150.37.0/24 synchronize=no
add disabled=no network=216.150.38.0/24 synchronize=no
add disabled=no network=216.150.39.0/24 synchronize=no
add disabled=no network=216.150.40.0/24 synchronize=no
add disabled=no network=216.150.41.0/24 synchronize=no
add disabled=no network=216.150.42.0/24 synchronize=no
add disabled=no network=216.150.43.0/24 synchronize=no
add disabled=no network=216.150.44.0/24 synchronize=no
add disabled=no network=216.150.45.0/24 synchronize=no
add disabled=no network=216.150.46.0/24 synchronize=no
add disabled=no network=216.150.47.0/24 synchronize=no
/routing bgp peer
add address-families=ip as-override=no comment="ACC AT&T" default-originate=never disabled=no hold-time=3m in-filter=isp1-in instance=default multihop=no name=
nexthop-choice=default out-filter=isp1-out passive=no remote-address=12.250.170.117 remote-as=7018 remove-private-as=no route-reflect=no tcp-md5-key="" ttl
use-bfd=no
add address-families=ip as-override=no comment=TWC default-originate=never disabled=no hold-time=3m in-filter=isp2-in instance=default multihop=no name=toISP2
nexthop-choice=default out-filter=isp2-out passive=no remote-address=50.84.34.213 remote-as=11427 remove-private-as=no route-reflect=no tcp-md5-key="" ttl=
use-bfd=no
/routing filter
add action=accept chain=isp1-out comment="Accept our own network and prepend second network" disabled=no invert-match=no prefix=12.217.156.216/29 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.32.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.33.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.34.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.35.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.36.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.37.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.38.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.39.0/24 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.40.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.41.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.42.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.43.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.44.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.45.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.46.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp1-out disabled=no invert-match=no prefix=216.150.47.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=discard chain=isp1-out comment="Discard the rest" disabled=no invert-match=no set-bgp-prepend-path=""
add action=accept chain=isp2-out comment="Accept our networks and prepend AS path three times" disabled=no invert-match=no prefix=12.217.156.216/29 set-bgp-prepend=3
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.32.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.33.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.34.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.35.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.36.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.37.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.38.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.39.0/24 set-bgp-prepend=3 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.40.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.41.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.42.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.43.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.44.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.45.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.46.0/24 set-bgp-prepend-path=""
add action=accept chain=isp2-out disabled=no invert-match=no prefix=216.150.47.0/24 set-bgp-prepend-path=""
add action=discard chain=isp2-out comment="Discard the rest" disabled=no invert-match=no set-bgp-prepend-path=""
add action=discard chain=isp1-in comment="We do not need any routes from both ISPs, because default route is used to force outgoing traffic through ISP1 and leave ISP2 as backup
. OJO ESTO PUEDE O NO REQUERIRSE !!!" disabled=yes invert-match=no set-bgp-prepend-path=""
add action=discard chain=isp2-in disabled=yes invert-match=no set-bgp-prepend-path=""
Thanks a lot for your help.
J. Boardman
