Hi Guys,
Only recently I have acquired my /22 from Ripe and have been assigned my AS number also.
I have a BGP session established with my upstream provider, and I have ospf running between my BGP router (1200) and a remote router (2011).
On the 2011, I created a bridge and put a public ip on it, 185.xx.xx.1/30. I can ping this IP now from anywhere on my network.
But outside of my network I can not and my provider is not picking up my routes either.
Under BGP networks I put in 185.xx.xx.0/22.
Under BGP instances I put in redistribute ospf
Under BGP advertisements I can see the 185.xx.xx.0/30 coming up. I can also see the private range…is this right?
I have tried everything but can not get these routes out. What else should I be doing?
“/routing bgp advertisements print” will show you what you are advertising to you provider. You should only see your public subnet(s) advertised to your provider.
note: you should probable add filtering on the BGP-in chain as well depending on what you want your provider to share with you.
Ok I have populated the routing/filter rules exactly as you said. Nothing has changed.
But under routing bgp advertisements I can see all my privates, but no publics.
OK, If you privates are still being advertised then the filters are not working quite yet.
We need to know what your filter chains are called. In /routing bgp peer, what are the in and out filters? … /routing bgp peer export
also in /routing ospf instances there are the other in and out filters that are in question. /routing ospf instance export
what the current advertisements? “/routing bgp advertisements print” Is it all your ospf private subnets that are being advertised and no public’s at all or?
Also are you sure your upstream provider is accepting your public subnet(s) in there filter?
Wait… the 185.xx.xx.0/30 is the gateway to your upstream provider right? not the /30 on your internal network…
I have nothing set up in in/out filters at all. Never came across anything in the wiki about that.
My current advertisements show all the privates I am using between both routers and subnets connected to those routers also all accept my publics, 185.xx.xx.0/22
My gateway to my upstream is not anything in 185.xx.xx.0/22, but rather their own ips.
you should only be concerned with your barrier router and the /30 that you share with your provider on that router. I believe this is your rb1200. It is the one that connects to your provider right?
You need to figure out what chains you need to be working with here. You need to find the outgoing bgp chain that I referenced as ISP1_Out above.
On our outgoing BGP chain you need only two rules.
first accept your /22.
then drop all other routes.
This is because your provider only cares what public networks you have.
The only other thing you should need to do is make sure that your OSPF is not sharing internal routes over you bgp session. This is the third rule from above.
on the ospf-out chain you need to discard everything across the /30 that you share with your provider. (the /30 that the bgp session is on)
To find wich chains you are using for your ospf and bgp out you can run…
change
redistribute-connected=yes
to
redistribute-connected=no
We don’t want to redistribute all the connected routes on the router because you might have some private addresses on the router at some point. As long as you have your public /22 in your bgp networks then we should be able to use the routing filters to advertise just your public /22 to your provider.
The bgp chains we are interested in are in BGP peers.
It will look like this
/routing bgp peer
add in-filter=<name of the in filter to be used in /routing filter for this peer> name="<providers name>" \
out-filter=<name of the out filter to be used in /routing filter for this peer> remote-address=<peers IP>\
remote-as=<your peers as number> ttl=default update-source=<interface name>
Try to set up your filters as follows. For now we will just go though your out filters because that is what is necessary for your provider to recognize your public subnet.
/routing filter
add action=accept chain=<the out filter in bgp peer> prefix=<your public /22>
add action=discard chain=<the out filter in bgp peer> prefix=0.0.0.0/0 prefix-length=0-32
add action=discard chain=ospf-out prefix=<the /30 that you share with your provider... it is the /30 that the remote-address of your bgp peer is within >
Then run…
Hopefully the only thing that you will see advertised is your public /22.
I have tried to ping and winbox into the public ip I have given to the remote router but am unable to establish a connection.
using the online traceroute to trace the ip does not know where to go.
Should the AS-PATH area not be populated under advertisements?
Could it be possible my isp is not advertising my /22 correctly?
aut-num: AS31018
as-name: VikenKomTek
descr: Viken KomTek AS
org: ORG-VKA6-RIPE
import: from AS41572 accept ANY
import: from AS2116 accept ANY
export: to AS41572 announce ANY
export: to AS2116 announce ANY
admin-c: TA3394-RIPE
tech-c: TA3394-RIPE
mnt-by: RIPE-NCC-END-MNT
mnt-by: MNT-WISP24
mnt-routes: MNT-WISP24
