I have a problem with bgp peering negociation, some mikrotik anunced bgp capabilities, produces in cisco router that reiniciate session.
Can I moddify Capability Negotiation of mikrotik peer?
Anyone can help me?
This is a great disadvantage when peering with mikrotik to a IXP (Internet Exchange Point).
routeros 4.3 peer configuration:
name=“peer-xxxxx-looking-glass” instance=default
remote-address=xx.cisco.ip.xx remote-as=xxciscoasxx
tcp-md5-key=“” nexthop-choice=force-self multihop=no
route-reflect=no hold-time=45s
keepalive-time=15s ttl=255 in-filter=xxxx-in out-filter=xxx-out
address-families=ip default-originate=never remove-private-as=no as-override=no passive=no
Mk log:
04:13:34 route,bgp,info Connection opened by remote host
04:13:34 route,bgp,info RemoteAddress=xx.cisco.ip.xx
04:13:34 route,bgp,error Received notification
04:13:34 route,bgp,error OPEN error: unsupported capability
04:13:45 route,bgp,info TCP connection established
04:13:45 route,bgp,info RemoteAddress=xx.cisco.ip.xx
04:13:45 route,bgp,error Received notification
04:13:45 route,bgp,error OPEN error: unsupported capability
04:14:27 route,bgp,info Connection opened by remote host
04:14:27 route,bgp,info RemoteAddress=xx.cisco.ip.xx
04:14:27 route,bgp,error Received notification
04:14:27 route,bgp,error OPEN error: unsupported capability
Cisco log:
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX open active, local address XX.CISCO.IP.XX
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX went from Active to OpenSent
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX sending OPEN, version 4, my as: CISCOAS
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX rcv message type 1, length (excl. header) 26
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX rcv OPEN, version 4
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX rcv OPEN w/ OPTION parameter len: 16
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX rcvd OPEN w/ optional parameter type 2 (Capability) len 14
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX OPEN has CAPABILITY code: 2, length 0
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX OPEN has ROUTE-REFRESH capability(new) for all address-families
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX OPEN has CAPABILITY code: 65, length 4
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX unrecognized capability code: 65 - ingored
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX OPEN has CAPABILITY code: 0, length 0
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX unrecognized capability code: 0 - ingored
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX OPEN has CAPABILITY code: 194, length 171
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX unrecognized capability code: 194 - ingored
*Feb 10 06:50:57.053: BGP: XX.MK.IP.XX went from OpenSent to Closing
