I am experiencing a pretty frustrating behavior where the BGP Best Path Selection algorithm appears to completely ignore the IGP (OSPF) metric to the BGP next-hop when breaking a tie for iBGP routes.
Topology
CHR running ROS 7.23.1
Two iBGP sessions (
BorderGate1-1andBorderGate2-1) established to two separate upstream routers over WireGuard tunnels. -
Internal routing to the BGP next-hops is handled dynamically by OSPF (as IGP)
The Problem
Both BGP peers are sending the default route (0.0.0.0/0). The BGP attributes (local-pref=100, med=0, and as-path="64515") are completely identical on both candidates.
According to the documentation, Step 9 in the route decision algorithm should pick the path with the lowest IGP metric to the BGP next-hop (everything equal). To my understanding, Steps 1-8 should be identical between my two routes.
My OSPF routing table shows a clear, definitive difference in metrics to reach the next hops (ospf.metric 10 vs 75):
[admin@SunGate2] > /routing/route/print detail where dst-address=172.20.215.129/32 or dst-address=172.20.215.130/32
Flags: X - DISABLED, F - FILTERED, U - UNREACHABLE, A - ACTIVE; c - CONNECT, o - OSPF, b - BGP
Ao afi=ip contribution=active dst-address=172.20.215.129/32 routing-table=main gateway=192.0.2.184%wg-bg1-ftth
immediate-gw=192.0.2.184%wg-bg1-ftth distance=110 scope=20 target-scope=10 belongs-to="ospf-instance-1"
ospf.metric=75 .type=intra
Ao afi=ip contribution=active dst-address=172.20.215.130/32 routing-table=main gateway=192.0.2.176%wg-bg2-ftth
immediate-gw=192.0.2.176%wg-bg2-ftth distance=110 scope=20 target-scope=10 belongs-to="ospf-instance-1"
ospf.metric=10 .type=intra
Despite 172.20.215.130 having a significantly lower OSPF metric (10), RouterOS installs the route via 172.20.215.129 (OSPF metric 75) as the active route:
[admin@SunGate2] > /routing/route/print detail where dst-address=0.0.0.0/0 and routing-table=default_uplinks
Flags: X - DISABLED, F - FILTERED, U - UNREACHABLE, A - ACTIVE; c - CONNECT, b - BGP
b afi=ip contribution=candidate dst-address=0.0.0.0/0 routing-table=default_uplinks gateway=172.20.215.130 immediate-gw=192.0.2.176%wg-bg2-ftth
distance=200 scope=40 target-scope=30 belongs-to="bgp-IP-172.20.215.130"
bgp.session=BorderGate2-1 .as-path="64515" .local-pref=100 .med=0 .origin=igp
Ab afi=ip contribution=active dst-address=0.0.0.0/0 routing-table=default_uplinks gateway=172.20.215.129 immediate-gw=192.0.2.184%wg-bg1-ftth
distance=200 scope=40 target-scope=30 belongs-to="bgp-IP-172.20.215.129"
bgp.session=BorderGate1-1 .as-path="64515" .local-pref=100 .med=0 .origin=igp
Is this a bug?
If not, how is this supposed to work?
In the case it just uses administrative distance as a discriminator, this is the wrong property because ospf.metric is what defines the cost to the respective default gateway.
I know I can overwrite these manually with route filters and such but it's important that the preference of this default route is really set by the cost of the underlying IGP (OSPF).
Thanks in advance!
