how do i block p2p traffic on my RB493AH? i have very limited internet at the moment so i want to filter or block p2p traffic while i wait my dedicated internet line.
Could someone tell me where to download regexp and miktrotik firewall rules to block p2p traffic.
I use the L7 in the mangel rules combined with the normal Mikrotik p2p detection and add mark them as p2p and then I have a filter that blocks it.
This disables the normal tracker and the DHT and peer exchange.
Please try it and if you can find any way to get around it please let me know >
p.s
You will have to disable DNS query’s outbound and only allow the DNS server in the Mikrotik.
d.s
Go to the Firewall Mangle.
Create a new rule
Set it as a prerouting chain and set L7 accordingly.
Set Action Jump and Jump to target lets say p2p-traffic
Do this for all the defined L7 filters and also for the default p2p-all
Create a new rule below
Set it as a p2p-traffic chain (you will have to enter it).
Set action to mark connection and set it to lets say p2p
Go to the firewall filter
I have put it on top but this is depending on your own setup.
Create new rule
Set chain to forward and connection mark to p2p, Then action to drop or if you use jump rules set it to jump and then point to the drop rule.
That is my config yes, Or to be more accurate the basics of the setup. You will have to adjust it to your setup.
Can you be more specific about what confuses you?
Create a new rule
Create new rule
You can just type it in the terminal, But I would recommend you to use this as a guide only. All configurations are different so you will have to adjust it to your setup.
The thing I would recommend is that is high up in the mangle and filter rules to make sure no other rules interfere with it.
