Hi there,
I’ve been asked by one of customers - to completely block world of war craft the game. I’ve tried various rules to do this, but the game seem to be still getting access. I have a feeling this is the do with the another related issue, whereby I wasn’t able to completely block a computer’s access. - Post: http://forum.mikrotik.com/t/drop-all-on-list-doesnt-seem-to-be-working/38391/1
Is there a L7 (or something) rule I can use to block world of war craft on a specific IP address or across the whole network?
Blizzard Entertainment own specific address ranges - so find them out and block all communication to them. I know that cause i’m prioritizing it over all other traffic - making sure that all packets get though my QoS no matter what.
Why do you need to block such a nice game? If children play too much - just stop paying for it
Hi Thanks for your inputs guys; I don’t really need to ask why this customer wants to ban the game as it not my place to ask.
I’ve got the rules on the unit but the pass through is still occuring for some reason; I really can’t figure out why my firewall isn’t blocking these rules I’ve made.
I think its time to send a support file to Mk.
When I get back I’ll post my rules up and see if anyone can see anything I’m missing.
Do a Google search for “world of warcraft port”. Posts on the WoW user forum verifies without TCP port 3724 open, the game will not work. TCP 3724 for the game data, UDP 3724 for the voice. Did you try the rule above for blocking port 3724? In case it was not obvious, use the src-address for your local computer/network, and dst-port=3724. The src-port will probably not be 3724.
As a test, you might want to try this:
add chain=forward action=add-src-to-address-list dst-port=3724 protocol=tcp address-list=WoW
Move this rule to the top. Then use WoW. See if anything ends up in the WoW list here
/ip firewall address-list
ADD: Do you have any entries in “/ip firewall mangle”?
Thank you for your help guys - I’m running the test to see if the simple firewall rule is picking up the ports. Failing that Chupaka useful resource of l7 extract will be put in place!
Ok so good news the firewall is detecting this string and marking correctly. Based on this what rule would you use to drop it - because the one I’ve made isn’t dropping the connection.
