Bonding with two PPOE interfaces from the same ISP
i have tried to add the bonding, but when i choose the ppoe1 and ppoe2 as the slaves for the bonding, i get an error stating that ppoe connections cannot be slaves?
I am not sure where to go next as i cannot find any documentation on this.
The isp has a multilink setup on their side, and assigned one static ip to both connections.
When i do a speed test, it is only using one link.
I cannot find any examples of bonding with ppoe, unless i am supposed to bond on the ethernet, as i really dont know.
Could someone kindly point me in the right direction.
Ethernet bonding is not the same as PPPoE MultiLink. Likely you want this https://wiki.mikrotik.com/wiki/Manual:MLPPP_over_single_and_multiple_links#MLPPP_over_multiple_links
Thanks very much, i have been searching for this, but obviously, the wrong topic.
Thanks again.
f
