Booting with own basic config
Is there a way to perform a routerboard device boot sequence in order to :
1: reset configuration without default configuration
2: load a custom configuration with just few lines
all at same time with no operator ineraction ?
Somebody will have to plug the cable. Flashfig or Netinstall are the best option.
If you still have access to the device remotely, “/system reset run-after-reset=customscript” is a possibility.
