Bridge 2 vlans
Any advice on the best way to achieve this??
Diagram would help, in terms of configuring hex… this reference is spot on for vlans.
Bridging means the two subnets would become one: one ip range. Is that what you want?
Or do you meant to route traffic between these two vlans?
Yes intervlan routing would work. can I do this on the hex.
Does anyone have a script for this??
Two elements needed:
  • ensure that router on each end knows where/how to forward traffic for the “other end”
  • ensure that forward is allowed in /ip firewall filter chain=forward …
can i do this with just one router??
anyone have a firewall script??
possibaly yes, if you can physcally have the hex router at the same location Aruba switch. so that network 1 is plugged in one port and network 2 is plugged in another. this way the hex will handle the inter-vlan routing.
or if you have a router uplink from the Aruba switch, this router can also do the inter-vlan routing. but your existing topology may not work with these changes. Again, a netowrk diagram would save us from guessing.
