Is it possible to bridge ether1 with a eoip and use a dhcp-server from a remote routerboard ?
I have the following set-up
Main Board—> Ap <— Second Board
eoip<------------------->eoip
dhcp-server<---------Bridge ether1 with eoip ( pc’s on ether1 with get assigned address from dhcp-server on main board )
Is this wrong> or is there a better method of doing it ?
that would work, but if you are working with cpe, realize that by bridging ether 1 to the tunnel means that if the customer hooks a switch to your device, anything they connect will draw from the dhcp-server.
Thanks I got it work but it is not the ideal solution.
What I am trying to achieve is to get Windows Network Discovery to work across to 2 different subnets.
As far as I know I can do this via a wins server or AD but would like to do it with Mikrotik
