Bridge Filter MAC + Mask
how does the mac and mask fields work on bridge filter ?
I tried to filter some traffic that should go out only to specific devices from within a mac range (filtered by vendor id) but the filter doesnt match any packets.
what i tried was:
  1. mac address 00:00:00:00:00:00 and mask XX:YY:ZZ:FF:FF:FF where XX:YY:ZZ is the vendor id ← nothing matches
  2. mac address XX:YY:ZZ:00:00:00 and mask 00:00:00:FF:FF:FF ← nothing matches
  3. mac address XX:YY:ZZ:00:00:00 and mask XX:YY:ZZ:FF:FF:FF ← nothing matches
  4. mac address 00:00:00:00:00:00 and mask FF:FF:FF:FF:FF:FF ← nothing matches either
Since there’s no doc on this topic on the wiki, can somebody please explain ?
Thx
Have you tried a *, don’t think that will work either, think it has to be an exact match.
I know this is an old post, but I was looking for the same information and couldn’t find it anywhere. Here’s what I worked out:
To match only data from dell devices (for example),
Src MAC Address: 00:1A:A0:00:00:00
Src Mac Mask: FF:FF:FF:00:00:00
This rule will match 00:1A:A0:xx:xx:xx
I haven’t tried it, but the mask field seems to be a bit mask, so you should be able to match ranges much like you can with subnet masks.
t
@thegink
Thanks, that worked like a champ..
Casey Annis
Can this be done in IP firewall? MAC Address and Mask?
