Is it possible there is a bug in the bridge filter on this device and firmware? (I never used this device before so haven’t tried ROS6 but tried some versions of 7)
I’m trying to block PPPOE going through a bridge. It only works sporadically.
Fast path and fast forward are disabled as far as I can see, but there are still fp- packets showing in stats.
The numbers only increase randomly, very seldom.
[admin@hs42] > /sys resource/print
version: 7.16.1 (stable)
build-time: 2024-10-10 14:03:32
factory-software: 7.12
free-memory: 394.9MiB
total-memory: 512.0MiB
cpu: ARM
cpu-count: 2
cpu-frequency: 800MHz
cpu-load: 3%
free-hdd-space: 103.3MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 87
write-sect-total: 359426
bad-blocks: 0%
architecture-name: arm
board-name: L009UiGS
platform: MikroTik
[admin@hs42] > /int bridge/settings/print
use-ip-firewall: no
use-ip-firewall-for-vlan: no
use-ip-firewall-for-pppoe: no
allow-fast-path: no
bridge-fast-path-active: no
bridge-fast-path-packets: 0
bridge-fast-path-bytes: 0
bridge-fast-forward-packets: 0
bridge-fast-forward-bytes: 0
[admin@hs42] > /int bridge/print
0 R ;;; defconf
name="br-bb" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=xx:xx:xx:xx:xx:xx protocol-mode=rstp fast-forward=no
igmp-snooping=no auto-mac=no admin-mac=xx:xx:xx:xx:xx:xx ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6
vlan-filtering=no dhcp-snooping=no port-cost-mode=short mvrp=no max-learned-entries=auto
[admin@hs42] > /int bridge/filter/print
0 chain=forward action=drop in-interface=ether3 mac-protocol=pppoe-discovery
1 chain=forward action=drop out-interface=ether3 mac-protocol=pppoe-discovery
2 chain=forward action=drop in-interface=ether3 mac-protocol=pppoe
3 chain=forward action=drop out-interface=ether3 mac-protocol=pppoe
[admin@hs42] > /int bridge/filter/print stats
Columns: CHAIN, ACTION, BYTES, PACKETS
# CHAIN ACTION BYTES PACKETS
0 forward drop 1104 24
1 forward drop 0 0
2 forward drop 0 0
3 forward drop 1965 7
[admin@hs42] > /int monitor-traffic ether3
rx-packets-per-second: 1 591
rx-bits-per-second: 2.0Mbps
fp-rx-packets-per-second: 8
fp-rx-bits-per-second: 11.2kbps
tx-packets-per-second: 2 603
tx-bits-per-second: 25.1Mbps
fp-tx-packets-per-second: 0
fp-tx-bits-per-second: 0bps
tx-queue-drops-per-second: 0
1 forward drop 0 0
2 forward drop 0 0
10 minutes later
1 forward drop 0 0
2 forward drop 0 0
If I add just a “catch all” it only captures bytes and a few packets while there is over 20Mbps going through the interface:
[admin@hs42] > /interface bridge filter add chain=forward in-interface=ether3 place-before=0
rx-packets-per-second: 1 206
rx-bits-per-second: 1321.0kbps
fp-rx-packets-per-second: 5
fp-rx-bits-per-second: 8.2kbps
tx-packets-per-second: 2 966
tx-bits-per-second: 29.2Mbps
0 forward 56709 216
1 forward drop 1196 26
2 forward drop 0 0
3 forward drop 0 0
4 forward drop 1965 7
0 forward 56853 218
2 forward drop 0 0
3 forward drop 0 0
[admin@hs42] > /int bridge/filter/print stats terse
0 forward 56997 220
2 forward drop 0 0
3 forward drop 0 0
0 forward 57316 223
2 forward drop 0 0
3 forward drop 0 0
There is also PPPOE sessions flowing through the interface with no problems.
Any idea how this is possible and what I missed?
