Bridge filtering on CRS354-48G-4S+2Q+RM
Hello Team,
I tried to configure bridge filtering on my CRS354-48G-4S+2Q+RM, but I haven’t been able to get the traffic to be handled by the hardware. Here is an example of my configuration:
[admin@MikroTik] > interface bridge filter print
0 chain=forward action=drop mac-protocol=ip src-address=10.0.0.2/32 dst-address=10.0.0.1/32 ip-protocol=icmp
[admin@MikroTik] >
Could you please confirm whether bridge mode L3/L4 filtering is supported on this device, or if there is any known issue/bug in RouterOS version 7.14.3 (stable) affecting this functionality?
Thank you in advance for your assistance.
The answer to your question is really simple: bridge filtering is a software only function. Switch rules are however executed in hardware and are line rate.
Usually, wanting bridge filtering is a sign of a network architecture problem. You should have a hard look at what exactly you are trying to solve, and how to do it properly.
Just to clarify:
  • Bridge filtering → allows filtering based on L3/L4 information (IP addresses, ports, protocols), but all traffic is processed by the CPU (software).
  • Switch rules → are executed in hardware (ASIC) at line rate, but they only support L2 filtering (MAC, VLAN, EtherType, ports); L3/L4 filtering is not possible, only redirect to cpu.
My question is:
Is there any MikroTik function (or device) that can:
  1. Stay in bridge mode,
  2. Filter based on L3/L4 information,
  3. Have the traffic handled in hardware (line rate),
  4. Support speeds greater than 1 Gbps, and
  5. Allow a large number of ACL entries/rules?
Not correct! Your CRS switch has support for 170 ACL rules:
CRS3xx, CRS5xx, CCR2116, CCR2216 switch chip features - RouterOS - MikroTik Documentation
that can filter based on L3/L4 criteria
too. Please note this available action:
  • new-dst-ports (can be used to drop packets)
Use new-dst-ports="" to drop the matching frames.
So, if my understanding is correct:
  • I can use switch rules to match the traffic I want to allow, and then, at the end, I can add a generic rule like:
interface/ethernet/switch/rule/add switch=switch1 ports=ether1 src-address=0.0.0.0/0 dst-address=0.0.0.0/0 mac-protocol=ip new-dst-ports=""
to block everything else, similar to an explicit “deny” in classic ACLs?
  • Also, does this method align with my plan to have a device in bridge mode, filtering based on L3/L4 information, with traffic handled by hardware (not CPU)?
  • Additionally, according to the Mikrotik documentation, my device supports 170 ACL rules. Is this the same as the number of switch rules?
Most firewalling should be conducted at L3.
Yes, you can filter with switch (ACL) rules and it is handled in hardware by switch chip without sending traffic to CPU.
I’m not 100% sure on this, but you might not get 170 rules into the hardware before the switch chip resources are exhausted depending on how many conditions you add to each rule. I know that can be the case with some of the older switches, but maybe not with the chip in a CRS354. After adding all your rules, you can print the rule table and check if any of them have the invalid tag.
