bridging and firewall setup
Hello All, i have a new Mikrotik Hex router , and i was wondering if i put it into bridging mode, and then plugged our modem into the WAN port (of the mikrotik) , then our LAN into one of the LAN ports on the mikrotik, would that make an effective firewall for our client computers and also would it be a fairly quick setup addressing wise?
Thank You.
Regards.
Graham
WAN and LAN interfaces on hEX are valid only if you use factory configuration of Mikrotik. This device uses LAN1 as WAN interface and LAN2-5 as LAN interface.
If you configure your hEX as bridge will actuate as “switch” and if you want to use integrated firewall, you should enable it using this command:
/interface bridge settings set use-ip-firewall=yes
Regards
