BTH connection stops working after a short period of time
Hi guys,
I have a Huawei DN9245X6-10 router from my ISP with a 4G sim , which is doing bonding of ADSL and 4G, so I am behind a CGNAT, and port fwd is not working.
So, Mikrotik BTH via relay usage is the only way to connect.
I noticed that BTH works for a while, moreover I connect fine and after a while I disconnect.
Then when trying to connect again, it never connects.
If I will go to BTH VPN page and toggle the VPN Prefer Relay Code from non to EU1 or the opposite, then I can connect, and connection is fine again until this happens again.
I tested it via a PC with official wireguard client (configured with a BTH users) and via Rustdesk I connected to a PC same LAN with BTH enabled mikrotik device (cAP XL) where I was toggling the relay code.
cAP XL is on 7.22.1
Any solution to that? to avoid toggling it and using rustdesk
Yes take supouts and report bug to mikrotik.
