Bug/Problem with Link-Color
i have a problem with the color of the links .. when a link is getting full it turns from green to red .. thats ok .. but then it was red and the load goes down a part of the link still shows red .. if i click on the link the color changes and shows the correct color …
Is this a bug? I already tried to disable gradients and antialising but no success :frowning:
Regards
What version are you running?
3.4 .. newest
I see what you are talking about. I’m playing with different probe interval and label refresh intervals for the map, link, and device to see if it makes any difference. But so far no luck.
It does seem to be something specific to the appearance data over-layed on the link (at least in what I am seeing), as the part of the link that does not refresh itself properly is adjacent to both sides of the box the data is in.
yeah right .. i have no idea on how to fix that ..
If you set the ‘link label full’ color to be the same as the ‘link label’ color (i.e. the appearance box doesn’t change color with the link when its full), it does not seem to be as noticeable.
Regardless, I think this is a minor graphical bug with how the Dude is refreshing the contents of the pane.
