It is all here in the topic: Buy hAP be3 Media - #131 by normis
I have no intention to start using The network tab. Capsman with CAP and wap ax already deployed and works. My issue was the mld interfaces byt I found the issue in m provisioning policy so it is all sorted now.
I assume sooner or later I need to look at the network tab byt that time is not now ![]()
Seems that we have to extend the standard "it solves all engeneering problems" set of zip ties and silver tape with a 3D printer.
Nice job ! ![]()
(or should I say "Cool job" ? )
honestly, good job
Are you going to start selling your new mounts and how much?
no
... but I can provide you print files ![]()
chlazeni_hapBE3.zip (496.5 KB)
Cool! Thanks!
If you're not joking
, this fan works on 5V - ARCTIC P8 Slim PWM PST
Does your device shutdown if you don't have a fan pointed at it?
Honestly, I don't know if my unit has better cooling or something but here are my temperature's.
I'm currently waiting on my second unit. It should arrive first week in November.
This unit is in the living room which is heated to around 23-25 degrees (wood burning furnace). Unit is working as a router/AP with default configuration on it.
You've won in production lottery. Congratulations!
Your datapoint would fit nicely in my half-@§§ed temperature expectation diagram
and it is definitely better than previously reported ones.
Yea, those temps are good now. I wan't to see if second router will have same temps.
You haven't considered the possibility that the sensor in the lottery...
is broken and is registering a lower value...
Probably not ... but at the desk during setting up, its has 65 °C ... so closed in ceiling it probably could have more ... be3 has 3 USBs ... and 12V fan on 5V is absolutely quiet. 1 USB Fan, 2USB - SMlight Zigbee, 3USB Hue Bridge
If Mikrotik add Zigbee support in the future (please Mikrotik) ... there might be 1 USB free for something ![]()
That's one of the possibilities... That's why I'm waiting for the second be3. I want to see if second unit will have the same temperatures.
I will try to measure temperature with my own sensor directly on the heatsink.
only for recap, but is there any eshop who sells be3?
Mkstore getic senetic or varia still not...which is last "official" date?
thanks
Honestly, there is no official date... My distributor said they ordered 6 pcs and it will be shipped to them on 30th of October.
I don't expect that supply chain will stabilise any time soon. At least not until 7.26 stable...
Be lite is available everywhere but for be3 you will have to wait... I've waited for my for almost 8 months...
