Searching through the forum I can’t seem to find any previous post regarding to the question in the topic.
This is the command I’m running at the terminal
/ip ipsec remote-peer remove [ find id=“blah” ]
I’m using tik4net 3.3.0 and using it in Visual Studio and writing C# code.
Among many things I’ve tried, I’m pasting in my last attempt.
ITikCommand printcmd = connection.CreateCommandAndParameters("/ip/ipsec/remote-peer/remove");
printcmd.AddParameter("=find", "");
printcmd.AddParameter("Id", "blah");
I know above code is wrong… (I had to try:P) but you get the picture.
So, how should I go about doing this ?
