cable length test
I’ve got mikrotik rb951g-2hnd, firmware is updated, routeros 6.4
There’s a feature in wiki - cable-test. It is described like this:
[admin@CCR] > interface ethernet cable-test ether1
       status: no-link
  cable-pairs: open:4,open:4,open:4,open:4
But as I run similar command on my device, I get:
[admin@MikroTik] > interface ethernet cable-test 1
  status: link-ok
-- [Q quit|D dump|C-z pause]
Why can’t I see more detailed info?
I am getting same as you.
But
is working fine.
I’ve tried to call it by name - same thing.
[admin@MikroTik] > interface print
 #     NAME                             TYPE         MTU L2MTU  MAX-L2MTU
 0  R  eth01_internet			ether       1500  1598       4074
 1   S eth02_lan			ether       1500  1598       4074
 2  RS eth03_lan			ether       1500  1598       4074
 3  RS eth04_lan			ether       1500  1598       4074
 4  RS eth05_lan			ether       1500  1598       4074
 5  RS ;;; Wireless
       wlan1				wlan        1500  2290
 6  R  bridge-local			bridge      1500  1598
[admin@MikroTik] > interface ethernet cable-test eth01_internet
  status: link-ok
Am I missing something?
I’m guessing they removed the more complete testing facility on low price hardware to shave cost (or its not supported in the cheap switch chips they use). My 951g-2hnd reports the same as yours, as well as my RB2011. If you notice, the login prompt next to the more thorough report says admin@CCR (“top” of the line).
I think vendor might describe this limitation in wiki.
It works only if there is no link. Run this command, disconnect cable and you will see the difference in output.
Well, it changes to
  status: no-link
But still no signs of cable length.
This is really strange, since even basic modern integrated NIC can diagnose broken pairs, cable length and so on.
According to: http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features
“Atheros8327 is present on RB2011 series(ether1-ether5+sfp1) RB750GL, RB751G-2HnD, RB951G-2HnD and RB1100AH, RB1100AHx2(ether1-ether5, ether6-ether10).”
Your device RB951G-2HnD has the same switch chip as the one I’ve tested (RB2011UAS-2HnD), so this function should work. Report it to: support@mikrotik.com
I’ve got a reply from techsupport - they are going to fix this in next RouterOS release.
Wasn’t fixed in latest ROS release… big surprise…
Guy at tech support is surprised also =)
In fact in works, but ONLY if something’s wrong with the link.
run the command and unplug the cable, see for yourself =)
Kinda weird, but still.
I needed to move to firmware 3.10 it seems…
Mine is 3.08, but 3.10 is available.
I also encountered this problem about 8 years later, which surprised me.
I want to know where the problem is.
I had same problem. I find solution, cable length can be seen only via winbox.
I could not see it via cmd or webfig.
To see more detailed info, just press the space bar on your keyboard
