on v6.x do not work any that is only on v7.x
you can use only my functions on v6
Example of 3 days (259200 seconds) and 1 hour (3600 seconds) ahead mar/04/2024 16:37:18
:global datetime2epoch do={
:local dtime [:tostr $1]
/system clock
:local cyear [get date] ; :if ($cyear ~ “…-..-..”) do={:set cyear [:pick $cyear 0 4]} else={:set cyear [:pick $cyear 7 11]}
:if (([:len $dtime] = 10) or ([:len $dtime] = 11)) do={:set dtime “$dtime 00:00:00”}
:if ([:len $dtime] = 15) do={:set dtime “$[:pick $dtime 0 6]/$cyear $[:pick $dtime 7 15]”}
:if ([:len $dtime] = 14) do={:set dtime “$cyear-$[:pick $dtime 0 5] $[:pick $dtime 6 14]”}
:if ([:len $dtime] = 8) do={:set dtime “$[get date] $dtime”}
:if ([:tostr $1] = “”) do={:set dtime (“$[get date] $[get time]”)}
:local vdate [:pick $dtime 0 [:find $dtime " " -1]]
:local vtime [:pick $dtime ([:find $dtime " " -1] + 1) [:len $dtime]]
:local vgmt [get gmt-offset]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
:if ($vgmt < 0) do={:set vgmt ($vgmt * -1)}
:local arrm [:toarray “0,0,31,59,90,120,151,181,212,243,273,304,334”]
:local vdoff [:toarray “0,4,5,7,8,10”]
:local MM [:pick $vdate ($vdoff->2) ($vdoff->3)]
:local M [:tonum $MM]
:if ($vdate ~ “…/../…”) do={
:set vdoff [:toarray “7,11,1,3,4,6”]
:set M ([:find “xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC” [:pick $vdate ($vdoff->2) ($vdoff->3)] -1] / 2)
:if ($M>12) do={:set M ($M - 12)}
:local yyyy [:pick $vdate ($vdoff->0) ($vdoff->1)] ; :if ((($yyyy - 1968) % 4) = 0) do={:set ($arrm->1) -1; :set ($arrm->2) 30}
:local totd ((($yyyy - 1970) * 365) + (($yyyy - 1968) / 4) + ($arrm->$M) + ([:pick $vdate ($vdoff->4) ($vdoff->5)] - 1))
:return (((((($totd * 24) + [:pick $vtime 0 2]) * 60) + [:pick $vtime 3 5]) * 60) + [:pick $vtime 6 8] - $vgmt)
:global unixtodatetime do={
:local ux [:tonum $1]
:local Fzerofill do={:return [:pick (100 + $1) 1 3]}
:local prMntDays [:toarray “0,0,31,59,90,120,151,181,212,243,273,304,334”]
:local vgmt [:tonum [/system clock get gmt-offset]]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
:local tzepoch ($ux + $vgmt)
:if ($tzepoch < 0) do={:set tzepoch 0} ; # unsupported negative unix epoch
:local yearStart (1970 + ($tzepoch / 31536000))
:local tmpbissex (($yearStart - 1968) / 4) ; :if ((($yearStart - 1968) % 4) = 0) do={:set ($prMntDays->1) -1 ; :set ($prMntDays->2) 30}
:local tmpsec ($tzepoch % 31536000)
:local tmpdays (($tmpsec / 86400) - $tmpbissex)
:if (($tmpsec < (86400 * $tmpbissex)) and ((($yearStart - 1968) % 4) = 0)) do={
:set tmpbissex ($tmpbissex - 1) ; :set ($prMntDays->1) 0 ; :set ($prMntDays->2) 31 ; :set tmpdays ($tmpdays + 1)
:if ($tmpsec < (86400 * $tmpbissex)) do={:set yearStart ($yearStart - 1) ; :set tmpdays ($tmpdays + 365)}
:local mnthStart 12 ; :while (($prMntDays->$mnthStart) > $tmpdays) do={:set mnthStart ($mnthStart - 1)}
:local dayStart [$Fzerofill (($tmpdays + 1) - ($prMntDays->$mnthStart))]
:local timeStart (00:00:00 + [:totime ($tmpsec % 86400)])
:return “$yearStart/$[$Fzerofill $mnthStart]/$[$Fzerofill $dayStart] $timeStart”
:put [$unixtodatetime ([$datetime2epoch “mar/04/2024 16:37:18”] + 259200)]
:put [$unixtodatetime ([$datetime2epoch “mar/04/2024 16:37:18”] + 3600)]
