Can hAP ac³ Router Work with External 4G USB Modems?
Hello everyone,
I am using a MikroTik RBD53iG-5HacD2HnD (hAP ac³) which has a USB 2.0 port.
Can this router support external USB 3G/4G/LTE modems, and if so, which models are officially compatible with RouterOS v7?
Is there a recommended list of tested USB modems for this device, or should I consider using an internal LTE module instead for better stability?
Thanks in advance!
https://letmegooglethat.com/?q=mikrotik+supported+modems
the first link to Mikrotik's help answers your question of supported devices.
