Hi, pardon my lack of proper technical language, I’ll try to be as clear as possible.
I have an home network (Mikrotik Router A, color red) with ip 192.168.1.1
This is also a VPN server (SSTP) on 20.20.20.1
I want to deploy a second Mikrotik Router B color green, in another location.
In this location internet is provided by a generic LTE modem, with DHCP server in class 192.168.1.1/24. I can’t change this.
The B router will be connected to A router using SSTP tunnel, so B will be an SSTP client.
The problem:
Since Mikrotik B must acquire a wan ip in class 192.168.1.x (eg. 192.168.1.50) in order to have internet, could this pose a problem in the rest of the configuration, considering that 192.168.1.x is also the class of my Mikrotik A router?
this is the network schema, I hope it’s clear what my question is…
Mikrotik has many options here … . Multiple LAN with the same IP address range are usually not very simple routing connections.
Maybe you should look at the following …
The ISP is giving you one subnet 192.168.1.0/24, which cannot be changed. But you can have multiple subnets in that one ISP subnet, that do not overlap in range.
That is 2 separate 192.168.1.x/25 or 4 separate 192.168.1.y/26 subnets. You might need to use proxy-ARP on Router B to reach the Router A subnet
Also SSTP (just as PPTP and L2TP) has a BCP option, which can link the LAN of Router A and Router B at network level 2, so it is just one LAN for level 3 subnet.
MT Documentation is for PPTP only, but it is the same for SSTP and L2TP. https://wiki.mikrotik.com/wiki/Manual:BCP_bridging_(PPP_tunnel_bridging)
Be aware that RST must be enabled on the bridges for the BCP to be activated.
You can’t change the network on the LTE modem, but you can on the router A. I recommend setting the low-use band to .200-250
such as 192.168.235.0/24 this will avoid similar problems in the future.
Yes @holvoetn, having different subnets behind Router A than between ISP and Router B would be an advantage for the LAN network. If OP is ready to change the subnet behind Router A, as a first requirement.
Secondly I have seen more ISP modem/routers in our country that allowed to select the X in the subnet range 192.168.X.0/24 , than that we had access to add eg Router B as a LAN Router for deeper and different private LAN subnets.
Normally this is remedied by some NAT or masquerade on Router B, towards the ISP modem/router, just to capture all that traffic ( mostly responses) coming from Internet.
Client devices can be connected to the ISP modem/router, but the major part is usually in the Router A LAN, or in the Router B LAN.
How LAN A and LAN B is interconnected can be in different ways, depending on needs and wishes.
With NAT and masquerade, the clients on the ISP/modem LAN will be reachable from LAN A and from LAN B, but will have problems in initiating connection to devices on LAN A or LAN B.
PS: This PS might be confusing, and probably not what is wanted …
One can even connect the "ISP modem/router "network, to the Router A LAN network, at layer 2, with the SSTP/BCP setup. But before you try, think again and again. This is bypassing Router B and Router A ‘WAN to LAN protections’. LAN A and ISP modem network, are then just 1 network.
